Greetings turbododge! I was poking around the local boneyard, and I found this beauty in a 94 Lebaron.
I was wondering if it's an infinity III unit, its got a broken bolt or something holding it in so i couldn't exactly yank it out to do more research, there's some oddities about it that don't match some images I've seen of the Infinity III.
My other question is, if it is an infinity head unit, would it be simple plug & play with the rest of the turbo dodge family like the other infinities, with say a 92 'tona? Don't wanna spend the time trying to liberate it from it's scrapped home just to find out I got bupkis lol.
That is definitely NOT any type of Infinity radio.
The Infinity radios will be clearly marked "Infinity" and the speaker panels will have the Infinity logo on them as well.
Keep in mind Infinity radios are used with separate amps on each speaker- it will NOT work with a standard audio system at all.
Drats, I was afraid that would be the case, I thought infinity units usually had it marked on the face but I figured I'd double check. My car does have the infinity system though so that's not a concern if I do manage to get lucky and find one. Thank you for the help!
It is not branded as Infinity, but it has all the same features as the Infinity units. This unit actually post-dates the Infinity III and is a Mitsubishi designed unit for mid to late 90's cars. If you look at the back, it should have a CD changer port. Read more about the various radio options here -> A Guide to Chrysler (Dodge, Jeep, Plymouth) Stereo ?Head Units?.
The Inifinity head units absolutely will work with normal radio systems. They just work better with the amplified speakers. I have run Infinity head units in every TD I've ever owned, some with stock speakers and some with aftermarkets. The amplified 6.5" speakers are kind of terrible IMO. The sound just seems off somehow to me. But, the 5x7 and 6x9 Infinity speakers are outstanding and coupled with the right head unit produce an amazing sound. My Daytona currently has Alpine aftermarket 6.5" speakers in the doors and factory 5x7 Infinity in the rear. All the speakers sound great.
@EvilcowRoland That was a very interesting read and very informative, thanks for linking that! Also good to know that the Infinity units work just fine with non-infinity radio systems. I'll keep that speaker combo in mind, I love the way the infinity speakers sound with my current Inf I deck! @Dr. Johny Dodge, Alright good to know, I wasn't sure if it was broken or a security bolt, and now you've settled that. I'll have to try that socket trick, might/should is good enough for me :laugh: . Good to know about how the Infinity speakers work, and any challenges I may end up facing in the future in regards to the Infinity speaker system.
Thank you both very much for the info! I think I'll snag the unit anyway, I could turn it into a very nice garage radio :grin2:
Hello -
Still tinkering with my electronic Navigator in an 89 LeBaron convertible premium. Ended up cycling through a few units for different reasons - got one that worked (replaced buttons) only to have the VFD apparently die, for instance.
Before I put another one in, I am doing some...
87 2.2 turbo 1 , can you tell me the primary resistance needed for our machines? I have misplaced and cannot find it. Looking at a coil .355 ohms, 300 ma max primary current, 6.9 millihenrys inductance. Thanks for your time.
Hey everyone...after a 5 year hiatus and while my Evo is at the paint shop and my E30 is awaiting parts...I pulled the GLH out of the corner and decided to give it some love. But...its been 5 years so I'm learning it all over again. I'm really hoping to get the harness installed and a new fuel...
Need some insight please.
Held on to the button in the down position too long while lowering the top. Heard nothing except now the top won't function and the windows will not go up and down. Checked 30 AMP breaker, it's good. Now I'm not sure where to start. All window motors are good as...
I thought I might share this for anyone interested. It's a simple DIY diagnostic tool for verifying if your coolant gauge works correctly. It's simply 2 wires with a 500 ohm resistor Potentiometer in the middle, encased in a novelty plastic shotgun shell (Just because I had it laying around...
