figures.. they gotta be odd about things LOL.. i wasnt sure i wanted to install a radio that fit the opening, i hate using those kits there a pain in the arse..
IMHO, Scosche kits suck monkey balls.
I usually use Metra. The kit i used last had the option adjusting the kit to allow the new head-unit to sit recessed. The front of the head-unit was then flush with the kit and didn't stick out all stupid like the crummy Scosche kits
FROM THE METRA INSTRUCTIONS:
If a surface-mount installation is desired, cut and remove the shaft supports from the Faceplate. Snap the converted Faceplate into the Radio Housing. Slide the DIN cage into the Housing and secure by bending the metal locking tabs down. Slide the aftermarket head unit into the cage until secure.
If an intermediate-mount installation is desired, attach the Snap Spacers to the outer walls of the radio opening. Slide the DIN cage into the Radio Housing and secure by bending the metal locking tabs down. Slide the aftermarket head unit into the cage until secure.
If a flush-mount installation is desired, slide the DIN cage into the Radio Housing and secure by bending the metal locking tabs down. Slide the aftermarket head unit into the cage until secure.
89 Daytona Metra kits
Obviously the cheap one-piece kit won't have those options.
