1 - 12 of 12 Posts
Doing some maintenance on my CSX-T. I need a set of good rear bump stops, mine are rotted through. I also need a complete set of rear shock bolts and nuts, all my stuff had to be cut off as it was all seized up.
Discussion Starter #2
I also need the upper and lower rear spring isolators. Sure wish the aftermarket offered these items.
Try downloading the efiche parts catalog for your year and get the part numbers. There are a few places that might have then NOS. Try rearcounter.com for one.
I don't know if yours could even be repaired with that much rust. If you find new ones, stay away from those salty beaches down there!
That's not rust from around here, the car lived in Minnesota it's whole life until a few months ago. I'd have to park in Galveston Bay for that effect hah. I have the part numbers and I have been looking around, found the rubber parts but not the coil seat. I'll try the links you gave, thanks. Cindy thinks she may have a pair, I will hit the junk yards if I can't find some. Problem with them is most of the K based cars have been crushed long ago.
Or just leave it parked in the street with all those dang floods y'all like to have down there! :surprise:
That would probably work
Pretty sure this is the cup I need https://parts.doverdodgeparts.com/p/59872759/4421072.html
There are two cups the one above 4421072 says that it's Shelby specific. Then there is 4228159 that's for the non-Shelby cars. Stinks there is a difference since if I find a set they'll likely be from a pedestrian model.
On the "Full Diagram" it's showing 3 different part numbers. Something to do with notches. I'd grab which ever one you need at that price. At least they're not 50 smackaroos each! :smile2:
https://parts.doverdodgeparts.com/a/59872759__6455178/REAR-SUSPENSION-SUSPENSION-COMPONENTS-Sport-suspension-standard-2-door-hatchback-4-door-hatchback-al/PK87250.html
Discussion Starter #12
Desert Valley Auto parts had a set they are removing from a 86 Dodge 600 convertible. I went ahead and took a leap of faith that they are the same. Will take up to two weeks for them to arrive. :|
1 - 12 of 12 Posts
