1 - 5 of 5 Posts
My 92 iroc daytona has the rear height off by 2inches one side is higher then the other.the shop toll me that new shocks will leak if the springs are not replaced. Well i went to pullapart and found a 90 es with52k mile on it and I took the springs off and they were not the same the es springs were higher and thinner and my iroc were biger and lower bu they didn't look bad at all.So i did the change anyway to see and the same thing happen no change in the height . well i think some thing bent or borken in the back . please any sugestion be very help full .
something is bent, rotten, or otherwise ruined. get it back on the lift and look real close. compare measurments with the known good side. how was the spring mount/ pocket up top? just had a acclaim in the shop with a rotted out mount.
well the mount is not broken and I got a new top ruber insulator in there and no change in the back . driver is still 1inch lower that that pass side. Any suggestion do I need to get my new spings and shock ??
1 - 5 of 5 Posts
