So it looks like no aftermarket options are currently being offered and the Mopar 4271393’s are long gone NS1. The M/AM body rear shocks use same lower M10x1.5 stud mount, washers & bushings, but use a 1/2-13 bolt/nut for the top eye bushing as opposed to the Rampage/Scamp, which uses an m10-1.5. So in theory you could use M-body shocks and either a bushing over the top mount bolt, or drill out the hole in the unibody rail to accept a 1/2” bolt and have replacement shock options available! Idk if anyone else has already found replacement shocks that work, just figured I’d share this FYI! Thanks
