I think I have asked this before, but if the junkyard doesnt have any shadows, what other td's would have the exact same parts?
Does the daytona,omni,charger,spirit,and lebaron share the same parts.
I am mainly interested in the manual transmission parts, to do a swap, and any other little stuff that may need replaced.
I am a car noob at heart, if you wanted to do a manual swap, would you have to replace the whole transmission shell, or can you just swap the innards?
off topic, but I am watching the blair witch project, and in the very beginning, the guy has a charger. kinda neat.
any TD transmission wise would be fine 525, 555, 520, 523 or 568. The cables you need from a sundance or shadow. The shifter would be the same in all of them more of less not L bodies and pedals get from a shadow or sundance or duster
Cool thanks, can you put the transmissions in order from best to worst? or did you already do that?
520 and 555 shifter is way different from the 523/568 shifter. Shift pattern is different and the 555 shifter has a pull up ring for reverse. Your best bet is the grab the shifter assembly from whatever car you pull the tranny out of. I have an A555 equipped car, but I grabbed all of the stuff from a later 523/568 car because I eventually want a 568.
Hope this helps.
