I assume you are refering to the seat belt retractor assemblies? Is the problem that they will not retract or they will not lock on sudden stops. Failure to retract is a common problem even in todays vehicles, you can remove them and try to clean and lube the assembly but I have never been able to correct that problem other than replacement.
My driver seat belt will not retract, I have to move it in by hand usually after removal, not putting it on, it stays tight and does lock so I am fine with that, it is not a saftey issue as long as you can make it tight and it does lock. Mine will lock me in the seat on a hard shift.
