Just get the original radiator recored, I spent a ton of time researching other possible fits and fans at for the most part it was a total waste of time. I paid $350 total to get mine recored at a shop that has been repairing radiators here in Atlanta for 30 years. They called a core supplier to have the core custom made to the number of rows available and the correct width for the OEM tanks to be soldered on to. If your passenger side tank is rotted, you can get a standard T1 radiator for a Charger/Omni and pirate the passenger end tank, they are the same. The drivers side has a custom neck, you can transfer the neck from your tank to a standard T1 radiator also if needed but you need a good radiator man with a good torch.
