1 - 6 of 6 Posts
I an csx-t wih an 89 t2 motor i just have it rebuilt and when i rev the engine it sputter or it bucks at 2000 and it wont go higher. I moved some vac hoses to where there suppost to be but it sputter at 2000 then goes the rest of the way when i rev it at idle and when i take it out it drives normal for like a mile then it start bucking at 2000.please help o and the engine light isn't on
I don't know if this will help but I had a turbo LeBaron that would not run over 3000rpm under load, in neutral it semmed fine. The problem turned out to be the H.E.P. ( the pickup unit inside the distributor)
MAP sensor failure causes the ECM to limit the car to 2000 rpm. Check that it's properly connected, both electrically and pneumatically.
1 - 6 of 6 Posts
