1 - 12 of 12 Posts
Cleaning out the garage, here's your "RWD conversion" kit:
Parts were removed By me from my old 91 2.5 dakota and stored inside my garage since removal.
1) Bare Block (common block)
2) Bellhousing/5-speed transmission
3) Exhaust manifold
$150/all 3
Cheap/free delivery possible in MI/WI/MN depending on your location and timetable.
I'll work on getting some pix uploaded here...
Discussion Starter #2
block pic shows the RWD specific mounting bosses
Good luck with sale wish I was closer (In upstate NY) always wanted to do a RWD swap but too many other want to do too!!
if I recall correctly there were two different bellhousings used ???
maybe depending on the trans ?
again IF I remember correctly one bellhousing is needed to use the supra or colorado transmissions - but I have no clue which one..
I'd have to say if you're going to scrap stuff at least save the bellhousing - it's the one part that IS hard to find - and the shipping won't be the deal killer the trans would be
I wish I could say I'd be interested in just "collecting" the B-H but not right at this moment .. sorry
but at least you could use it as a basket for storing other other things in the meantime..
though if you want to start the ultimate TD build , all you need now is the factory five cobra daytona kit and an R/T motor with two shelby valve covers
lol -take THAT to the next ford show ....
You are correct! The NP535 (which is what he has now) used a "Borg Warner" type 4 bolt bell housing pattern. They are close, but do not match up.
The later year trans, The NV (New Venture) 5 spd equivalent uses the Aisin-Warner inherited rear ball/trans mount pattern. This works with a lot of trans, from the Jeep to the Supra (R154 series family) and the Solstice/Sky Colorado/Canyon MA5.
1 - 12 of 12 Posts
