how much could i shave off a head without having to worry about a shorter timing belt ??
you'd be amazed how peppy a stock tbi gets with .040 off the head and redegree the cam (about 3° advance). you can go about .060" off the head w/o needing a shorter belt. there are other options like a larger tensioner pulley or relocate the tensioner puller. also remember when you mill the head you retard cam timing, so you need to accomidate for that.What all are you doing? Just raising the compression isnt gonna make a huge difference w/o the supporting mods,
pretty close to that. I'd advance the cam 2° at .030. with the degree wheel, I'd find some variance as much as 3°. but even at .030" advancing 2° works just fine.Allmotor, How far off does it throw your timing if you cut .030'' off. Was it 2 degrees retarded?
MP use to list one. I wonder if there isn't some other brand car a guy could use?were could i get a larger tensioner ???
Mike, check your PMs..MP use to list one.
If you know the part number could you also post it here. I'm also interested shaving some off the head and getting some more performance this next rebuild.Mike, check your PMs..
