1 - 11 of 11 Posts
Hi,
I got an 87 Shelby Charger, was previously tuned by someone else and recently the computer packed in, so I am looking to setup and program a new computer with an osterich 2.0
Would anyone be able to tell me where i could find the binary file so I can set it up with TunerPro, and if anyone has any additional advice or tips it would be greatly appreciated
Dave
Thank you so much
So the previous owner left a note
t-lm using a171 template
setup cal options
empty lag
ceflash
fixable boost
tagging limiter
Scale 4 bar map
scale n6pph injectors at 55 psi
setup peftbl 4 ported head and cam
setup boost control for 18-35 psi
switchable on pin input
setup spark table for 38psi
setup overboost to 38psi
setup rev limiter 8200 rmp
setup knock table for high boost
setups tagging limiter for 4500rpm
The problem I have is the computer chip is broken and I need to setup another one and program these settings into the new one.
I'm unsure how to find the bin file I need so I can programme it to the Osterich, and get the new chip working, sorry I am not very IT Savy
What do you mean the chip is broken?
Possible to get a hold of the previous owner?
Nobody is going have this very specific 4 bar bin you're looking for. Is the ECU a TII LM or GLH LM? Post a picture of the actual board with the case if you don't know.
I was able to track down the Bin files
Turbonator LM codebase
Is there any numbers an settings anyone has recomendations using to go with these notes when using mptuner:
setup cal options
empty lag
ceflash
fixable boost
tagging limiter
Scale 4 bar map
setup cal options
empty lag
ceflash
fixable boost
tagging limiter
Scale 4 bar map
Do you have any experience with tuning any vehicles?
If I was to tune a unknown vehicle to me, I'd lower the boost to minimum level and start with just making the car run well with a stock tune as all your hardware. Learn from the experience and grow slowly from there. Make no mistake, learning how to tune is a LONG term process. I've been at it for a few years and I know I still have a ton to learn.
Head to Turbo Mopar Forums - Home and sign up an account there, there are plenty of threads to read to learn how to tune, there are youtube starter video on MPTuner
Tuning Turbo Dodge is a dying art, not a lot of people on turbododge.com can tell you how to tune.
1 - 11 of 11 Posts
