1 - 11 of 11 Posts
This is my Shelby Lancer #79 with 70k original miles.
Car is complete with all correct Shelby badges, steering wheel, rims, caps, plate, working DEX 77 system, Valve cover, and working R12 A/C system.
Original motor, a555 transmission, rims/caps, and DEX 77 are in storage as well as the spare graphic red deck spoiler and hood vent. I also have the rest of the decals, but prefer them off the car at this point
Engine:
1989 Common block, Forged pistons, ARP rods and mains, Ported Oil pick-up/passage, Melling pump, Ported head, Delta Custom Camshaft, MP head bolts, MP head gasket, Port Matched Intake, 52mm throttle body
Turbo:
TU Quick Spool Super 60 turbo, TU SS Braided Turbo lines
ECU and Air/Fuel:
MP Plus 40's, Walbro 255l, Cooling Mist Alcohol/Meth system,
Accufab AFPR, 3 Bar Map, Turbo Xs Bov, Innovate LC-1 Wideband,
Optima Red Top Battery, K&N CAI, Gus Mahon's Grainger Valve
Relentless Performance Custom Front Mount Intercooler,
Relentless Performance Logic Module tuned with the car by Gary Donovan
Transmission:
1990 A568
TU Ultimate 6-Puck Ceramic Stage III Clutch
Booger Bushings
Exhaust:
Ported and Matched Exhaust Manifold
3" Mandrel bent flows to a Warlock muffler
Suspension:
Koni's
Poly Bushings motor/trans/bobble strut/sway bar bushings
Neon Strut Tower Bar
Brakes:
1991 Spirit R/T Hubs with Vented Drilled/Slotted Rotors
EBC Ceramic Pads
Rims/tires:
Tenzo TypeR 18's
Triangle Talon 225/40/R18
Nice looking car. I really like the wheels! does it have any under car rust issues since it was in Michigan? or is it as clean underneath as it is on top?
Thank you very much,
Zero rust. Has been garaged its entire life and very well taken care of. However, I am in the process of re-coating/powder coating the under body to make it a little more pretty:dancing:
I also have a FWD Performance Stage 5 ECU for it that will be installed once the new motor/clutch are broken in.
The front mount hoses and pipes are also getting a facelift, going with all black for that factory look. The blue just isn't cutting it.
I would also like to thank ALL of our great vendors for making this car possible.
Discussion Starter #9 (Edited)
UPDATE
Installed big valve ported head, water to air I/C, Comp triple bb turbo 58/53, TU exhaust manifold, and adj cam gear. All tuning done on pump 93 with A/C belt on.
Tuned with cam at centerline 0 degrees
Retarded cam 3 degrees, gained 35 hp.
Final #'s 365whp and 370ft trq. on 27 lbs of boost.
Discussion Starter #11
Beautiful car, I'm impressed by the effect of adjusting the camshaft
Thank you.
Played with cam timing this morning and here are my final #'s for now. I am at a total of 5 degrees retarded on my cam.
My car made 374.7 whp @ 27psi with a/f's 11.2-11.4
1 - 11 of 11 Posts
