My Omni has run perfectly since installing the S60 wiring back in 1997.
It was nice day so I decided to go to the car wash and clean him up.
A few miles from home it bucked a couple of times and stalled out.
I hitched a ride home, grabbed a fuel pressure tester and a spare HEP.
Back at the car I attached the FP gauge, gave it a try and fired it up.
Fuel pressure was fine so I started home and same thing again.
I swapped out the HEP, fired right up and once more I headed home.
Home I decided to run down my road a bit and it started acting up again.
Eyes were glued to the tach as a dropping tach was my HEP test.
4 K RPM, the tach needle was steady but it bucked and stalled out.
Almost home, I had to use my old quad to push it inside the shop.
I checked codes and got a code 43, never saw that one before??
I researched 43 as best as I could, it seems to be ignition or SMEC related.
The wiring is in excellent condition and the grounds are all in place.
I'm still working with only 1/2 a brain and one hand after my stroke.
So now I'm kindly looking for any advice on tracking down this issue.
Questions:
1: Never had a SMEC go bad, has anyone had one go bad like this??
2: I've never had a coil go bad, has anyone had one go bad like this?
(It's the 1990+ style that mounts with the thermostat housing.)
3: One lead should have 12 v, the other flash with the Engine cranking?
4: If the coil lead flashes does that eliminate the HEP and SMEC?
5: Can I jump the diagnostic connector to activate the starter?
Questions:
