1 - 2 of 2 Posts
Been searching but haven't seen anyone try this...
Got a rotted 86 E body Lebaron T1 vert and a nice 88 K body Reliant that needs a Turbo swap.
I heard the bulkhead is the same and the LM is run off a separate plug from the engine harness So is the 86 LM harness plug and run with a 88 K car?
I have pile of LM's and need it to run same day. Don't have a shop to let it sit for months playing with wiring...
Old School Hot Rodder
Two items, (1) the 88 will not have the wiring for the LM/PM system (2) the 88 probably doesn't even have the hole on the right side behind the shock tower for the LM harness and MAP sensor line to pass through.
LM to PM harness is part of the front end harness and runs across the firewall with the previously mentioned penetration on the right side. This ends up in front of the HVAC case air inlet portion. If you do have the large hole with a rubber plug in it then the job is easier. If all that is good to go, the next item is the 50 way bulkhead connector on the left side. You will need the pinouts for both, and the fastest way to make them match if needed, will be to rearrange the ones in the LeBaron harness to match the Reliant one.
Good luck with it!
1 - 2 of 2 Posts
