<!-- BEGIN TEMPLATE: carform_post -->
Category: Domestic
Status: Clean Title
I have a 1989 Dodge Daytona Shelby for sale, in Ohio.
Mileage: 10,000 since rebuild miles
Engine Size: 2.2L
Asking price is $10,000 PRICE REDUCED!
Time for a new toy, I have put 138 miles on this in the past two years. Only known issues are the T-top driver side will drip in the rain and the drivers side driveshaft is still a tad too long. Never notice it during most normal driving, but when pushed hard in a right hand turn you can feel it. They are Drive Shaft Shop axles and I never sent it back to get it shortened. I have been driving it for 8 years without any issues, but if you wanted to corner like crazy it would be. I think I also have a lower ball joint going out as I hear a pop in the front from time to time. I have a pretty recent carafax and it is flagged for the milage. When I restored it I put a new dash in it, I still have the old dash to go with the car. PIC LINK BELOW. Not sure why it say Alberta, but the car is in OHIO.
ENGINE AND DRIVETRAIN
Block
0.040-over stock 2.2
Wiseco pistons Skirts/top coated
All ARP Hardware
Cylinder Head -Done by MRPbody ported, oversized valves
Cometic Head Gasket
ARP Studs
Camshaft
Roller
Fidanza Adj
Intake Manifold
Ported one peice
Vac block
Alum Fuel rail
T.U. 3 core radiator
Throttle Body
52mm
Turbo
Turbonetics T3/4 50 trim Stage 2 Wheel
Spearco 1080
Turbo XS Boost Ctlr
Tial BOV
Exhaust
F.M. Stainless 3 inch mandrel bent
T.U. 3 inch S.V.
T.U. Stainless Header (coated)
Fuel System
+40's
Walbro 255 pump
Accufab A.F.P.R.
Earls lines with all AN fittings
All new lines brake/fuel
New gas tank/sending unit/fuel pump mount
Transmission
A555 with 5K orig miles on it, polished.
Mcleod Rev-loc
Purple plate
Chrome Molly end plate
Quaife LSD
Level 2 axles- THE DRIVESHAFT SHOP
Engine Managment
Stage 5 Cal
3 Bar Map
3 Bar progressive Devils Own Alky Inj DevilsOwn alcohol water injection
MSD Blaster coil
Magnacore wires
Gauges
The following are Auto Meter Ultra lite series
Boost 0-30
EGT
Water Temp
Elect Fuel Press
Oil Press
Innovate LC-1/XD-16 Wideband
Suspension and Chassis
Every bushing that Johnny makes is in this car
Custom Koni front and rear Adj coil overs
Brakes
S/S Sraided Lines
Carbotech, Bobcat pads
All new brake lines
Rebuild of my power steering unit- steerandgear
Chassis stiffening
Front strut tower brace
Rear swaybar
ADJ Panhard bar
https://drive.google.com/drive/folders/0B4zi1LJVOijKMFpIOFRpRTZvem8?ogsrc=32
<!-- END TEMPLATE: carform_post -->
Category: Domestic
Status: Clean Title
Engine Size: 2.2L
Block
All ARP Hardware
Cometic Head Gasket
ARP Studs
Camshaft
Roller
Fidanza Adj
Intake Manifold
Ported one peice
Vac block
Alum Fuel rail
Throttle Body
52mm
Turbo
Spearco 1080
Turbo XS Boost Ctlr
Tial BOV
Exhaust
T.U. 3 inch S.V.
Fuel System
+40's
Walbro 255 pump
Accufab A.F.P.R.
Transmission
Mcleod Rev-loc
Purple plate
Quaife LSD
Engine Managment
Stage 5 Cal
3 Bar Map
MSD Blaster coil
Magnacore wires
Gauges
Boost 0-30
EGT
Water Temp
Elect Fuel Press
Oil Press
Brakes
S/S Sraided Lines
All new brake lines
Chassis stiffening
Rear swaybar
ADJ Panhard bar
