1) The Grand Mini's and some of the minis came with 15 inch wheels, they came with the 11 inch big brakes and its just a bolt on! If you use 91 and up, you must swap over the k-member as they use the cast control arms and the required 91 and up knuckles.
2) Minis had the beefier control arms and thicker springs so I would stay with the mini stuff. Other models fit but they will lower the van 3-4 inches!
3) They didn't make manual racks and mini racks are mini only so I would just leave the p/s pump off and drive it like that!
4) I would simply get some used axles, take the end joints apart and just use the empty joint as the nut needs to be around 160 ft/lbs otherwise the bearing comes apart!
