1 - 11 of 11 Posts
i have a problem, my speedo was working but stopped now, it was an analog so i switch to digital now, evrything is hookled up correctly, speedo still doesnt wrk, where is the speed sensor located, mayb its bad
It's on the little axle shaft housing on the passenger side of the diff
you should be able to see it , from above ,down behind the motor where the starter is
Speed sensor does NOT provide input to the speedometer, just to the computer. Speedometer is driven by cable that the speed sensor is mounted on.
Yeah, 86 is actually the last year for cable speedos. They are the ones with 125mph to upgrade 84-85 cars. 87 was first elect only speedo.- and early(84-85?) digital cars.(did 84s have digitals? my 85 does)
is it the same set up as my 90 shadow? theres a tsb on fualty connectors on the distance sensor if its like my car. dont know if that helps.
My 86 daytona has a digital dash but it is cable in the tranny! What is the unit in the transmission called and where can I get one?
speed/distance sensor. i'll post up the factory mopar part # tomorrow so everyone can source a new one from mopar, they are still available.
Can someone post a picture of a correctly plugged in one. I don't think mine is all the way in because my speedometer is bouncing back and forth under acceleration. Thanks
1 - 11 of 11 Posts
