1 - 12 of 12 Posts
This is happening in my 89 daytona shelby 2.2 turbo. Randomly the speedometer will stop working and this is paired by stalls. Coming to a stop, I'll pop it into neutral and the rpms will drop until it eventually cuts.
Any ideas?
Could it be HEP related? Or possibly a problem with the speedo connection at the cluster...but I'm not entirely sure why it would stall if that's the problem
More than likely the speed distance sensor is going out.
If the SEMC can't see the speed of the car when you're coming to a stop, your engine will stall every time.
Usually replacing the speed sensor will fix the problem, unless it's a wiring issue.
Haven't replaced the sensor yet, but I'll try and get that done this weekend. Coming home from work tonight, the car tried to turn off 3 times. The lights would dim and the engine would cut, then turn on again immediately without me doing anything. I'm getting a code 46. The speedo was working this time so I'm not sure if this problem is related at all.
Code 46 is a charging system fault.
Easy enough to diagnose, you need a digital voltmeter and 12 volt test lamp.
If your vehicle has a Nipendenso alternator chances are the brushes are worn out ans are easily replaced.
Let me know when you are ready to work on the car and I can walk you thru it.
Discussion Starter #10
took the alternator to autozone and it failed twice, so I'm going to pick up a re-maned model. I also picked up a new distance sensor that I'm going to put in.
Hopefully you did not buy a new alternator yet.
You have an 89 Shelby and the alternator is probably a Nippendenso.
If it has a tin cover on the rear it is an ND.
Before buying a new one remove the tin cover and look at the brushes.
If the brushes are worn it will cause all of your issues and the brushes are replaceable for about $10.00.
ALTERNATOR BRUSH HOLDER BRUSHES DENSO CHRYSLER JEEP NEW | eBay
Discussion Starter #12
Unfortunately I have already bought it and purchased it. I wouldn't really have had the time to wait for the bushings to come in the mail since this is my daily drive. But I will remember this for the future. Thank you for all of the help
1 - 12 of 12 Posts
