1 - 6 of 6 Posts
Anyone know where we can find new spider conical washers and or gears as mine A568 all have annulus cracks.:poop:馃が
You might have better luck running an ad for a WTB for the whole diff. People changed them out if they bought a LSD for their cars.
Are you saying your spider/pinion gears are cracked?? Or just the washers?
I've built several Limited Slips over the years and always left the washers out.
Discussion Starter · #4 ·
the A568 has a quaife diff with 4 spiders but the washers are cracked if I leave them out the slop will be huge.
I didn't notice you have a Quaife and have no experience with them.
On regular 2 /4 pinion diff's I put a clutch or shim spacer under the axle gears.
This removes all slop with the conical washers eliminated.
Are you talking about the Belleville washers like in the OBX? I do have some actual Belleville washers I ordered to replace the OBX ones that were suspect. I don't know if they interchange with the OBX ones. Can you post a picture or give me some dimensions of the washers needed? Also how many are you looking for?
1 - 6 of 6 Posts
