ok since you asked,
first pair
they are the 2 better ones, i cleaned them up a little with meguiars plastx cleaner.
one has 2 little rock chips that you cant see in the pic, you have to look very close.
2nd pair
one has a liitle chrome starting to wear off at the outer edges and black is showing through, but looks good on the car, the other one has a little oversparay on the back of it and has a spider egg sack in the corner of the lense.
this pairs comes with the 8" wire lead and bulb socket but socket has the tabs broke a liltte.
here is the spare lense, its as clean as the first pair.
*these are the plastic ones that come on the 91-92 es, i can get the glass lensed metal housings ones too that came off the aa lebarons and the acclaims. they have a different bulb socket with the ruber around the socket but the connectors at the end are the same, so they are interchangeable, the mounts are different also.
