hello, i have a 90 daytona 3.0 and i have a squeal on idle which increases as the rpms increase. i removed the AC belt, still there, removed the Serpentine belt and its gone. I was able to take the belt off by just pulling up in it which makes me think maybe the belt or tensioner are bad? (both are new belt(dayco 702k5 71.5" Pitch Length - 72.25" Outside Measurement X 5 ribs) the power steering pump is new as well. Any ideas would be great as i was trying to get it to emissions this week.
Ryan
try a new belt from autozone.. if it goes on and stays on, even if you tug it. Then that was your problem (stretched belt)
if its the same as your current belt, you can return it and buy a tentionsioner.
if the PS pump and Alt. are in the correct spots (hard to believe that they somehow moved without throwing the belt off) then the tensioner is more than likely worn out.
Thanks, just got back from autozone and exchanged it for the same belt and that solved the problem.
