1 - 11 of 11 Posts
I have a 2001 PT Cruiser. Have been happy with the car and service I hve received from the dealer. Presently I have approx 25,000 miles and have noticed a clicking sound when I turn the steering wheel. Anyone else experience this?
Billy ball, welcome to the PTE. There are others who have had the same issue with the clicking noise in the steering wheel. I believe that the problem is with the clock spring. There is a TSB (technical service bulliten) for this problem. The TSB# is 1900601A (Component: Steering: Column - Experiencing steering column click sound when the steering wheel is turned.) If you give that TSB number to your dealer, they should know what to do. Good luck. :)
Thanks for the TSB#, I wasn't aware of that. Will pass the info to my dealer next service trip in. Thanks again for the speedy reply.
Thanks for that info... I have the same problem... but it isn''t that disturbing yet... I will give the TSB# to my dealer too. But I don't think they will know what to do... cause sometimes I think I know less then they do ;)
Actually, it is the upper half of the steering column that causes the problem and it is replaced with a redesigned unit. The clock spring is sometimes replaced because it is easily damaged during the repair. Definitely covered under warranty and a quick fix.
My 5 month old 2003 GT (5,000 miles) is making a noise when I turn the steering wheel also. It isn't a clicking, more like a rubbing sound that is very annoying. Sounds louder inside than outside. I would think that mine would have incorporated whatever fix was recommended in the TSB if the TSB has been out for a while. Noise is usually absent when I first start the vehicle but gets very noticeable after 5 or 10 miles anytime I turn the steering wheel (even a movement of an inch in either direction will get me the rubbing sound).
Any suggestions on this one?
Could be a couple of things. My clicking was a bearing at the top of the steering column. Swishing or rubbing tends to be the clock spring. Last time, I had a groaning sound which was worn tie rod ends (apparently). This sound has come back so it's off to try out a new dealership!
I had a ticking noise in my steering wheel and they said at the dealership that it was definitely the clock spring! :}
Get it? Ticking? Clock spring? Boy, who served novocaine to the audience?
1 - 11 of 11 Posts
