recently changed my speedo sensor, installed new plugs(old ones fouled), new head gasket,new vac lines to fuel psi reg, and other stuff not pertaining to my proble(jus needed to be done). but still my 86 t1 omni still stalls at clutch in no matter what speed but starts right up no problem after it stalls it idles fine but from what the plugs tell me i am running pig rich, so i am thinkin that is why i am pullin my hair out and can't play with my car. jus found my fuel presssure check tool thismornin( i moved recently)but i was also thinking possibly my map sensor has gone bad, or my fuel pressure reg has gone bad???? anyone have any input that may be of assistance so i can start killin hondas again?
thanks
Troy
checked my fuel psi and it was almost and even 50psi went upto 52psi at 2500rpm, also i do have a 225 walbro pump in my tank as well so i know it gets fuel the pump is not even 8 months old
thanks
Troy
