1 - 5 of 5 Posts
yes and no.
If you put this housing on a stock turbo without using a S60 compressor wheel, then you're really killing the reason to use it in the first place. There will be too much of a gap between the 50 trim wheel and the new super 60 housing.
Wink
You need the housing and the wheel, with those 2 items it's a direct bolt on.
bdub840 said:
ok Just as I figured, it also came w/ the super60 wheel as well.
If/when you go and do the upgrade on the compressor, make sure you have the turbine wheel/shaft and the compressor balanced. You can have it sent out to one of our venders, or you can find a place locally. I've found three Diesel truck repair shops locally that will do it really inexpensively.
Wink
93 Lebaron Conv 3.0L 5 speed
89 Sundance RS 2.5L turbo 3 speed
89 Shadow ES 2.5L turbo 3 speed
1 - 5 of 5 Posts
