1 - 12 of 12 Posts
Super 60 kit by mopar. Includes performance pcm, high volume fuel pump and injectors.
Brand new never used. Im moving cleaning out shop forgot I had this. I also have the mopar dodge turbo book that tells everything about the old dodge turbo cars. I will take some pics tomorrow or the next day. Make me an offer.
Pm sent
I think the term Super 60 kit might be a little bit misleading??
There was a Super 60 package that was comprised of many individual parts.
I bought every single component in the entire package way back in 1997.
There were at least 13 different part #s comprising the Super 60 package.
The only thing labeled as a kit was the P4529980 Turbo Kit.
This kit included the Turbocharger, +40 injectors and GM 3 bar MAP sensor.
Ironically, GM didn't use the 3 bar as a MAP, it was running a MAF system!
Some components were not needed, depending on which vehicle was used.
A few models came stock with the 2 piece intake and 1988-89's had SMEC wiring.
The wiring harness was specifically made to convert an 85-87 L body to SMEC.
My entire L body Super 60 package wholesaled for almost $6,000 in 1997!
This isn't totally accurate as the invoice included MP Engine mounts.
The 52 mm throttle body was not included but was a used part.
Hopefully someone finds this interesting !!
GLHS60
Agreed entirely, but the seller seemed very transparent about it and after some discussion with him it was apparent that it was a partial kit. I still took it as it had the parts I needed to get closer to my build. I'm an opportunistic builder and looking for people with aging parts they are tired of tripping over. These were all new unused from the mid '90's.
Right, only the injectors are part of the kit but they and the fuel pump are fine!!
Fittings for the pump used to be hard to find but are no doubt easier to source now.
Probably one of the best fuel pumps available !!
Its certainly a nice piece!! (P5249534)
They were about $700 to 800 back in the day.
Probably cost that much or more now if one was found.
That's why I asked.😁 Eventually if I come across the conversion harness, I'd like to convert Black Moon.
1 - 12 of 12 Posts
