21 - 29 of 29 Posts
yea the entire kit consisted of Ic : P5249331 , cam : P5249496 , comp P5249528 , head P4529353 , Turbo P4529980 , + 40s P5249452 , fuel pump P 5249511 totalling $ 3,732.00 there may be items i'm missing .
85GLHTretired, trying to put a value on something like your engine is like asking what is a 86 GLHS Omni worth. In the case of the car, it could be worth $1K (basket case) or it could be worth $20+K. It is ALL based on condition (the details).
I would need a lot more info to give you a "what's it worth" opinion. You can easily spend 6K building an engine, while some cut all kinds of corners and claim their re-ringed and bearing 175k mile std. bore cast piston $1k engine is just as good (lol). With your engine, I see it is an early block. Most people desire the later common blocks. A early block will support 300+ HP. Is this a rebuild or are components including block new? Does it have a steel or cast crank? Does it have main and head studs, or are they bolts? It appears to have a G-head. Is this a brand new MP big valve G-head? The MP valve springs failed a lot too. They just lost a bunch of open and closed pressure, not actual spring breakage. We all know the s-60 slider cam had almost a 100% failure due to it's design. Some may last 30k miles, while others lasted only a few thousand. They're a few out there still running them, but very few. Should have been a roller design not a slider. The MP heads were really sketchy as far as porting and flow. Could be okay, or could flow about what a stocker is depending on who ported it on any given day. Plenty of porters out there today that can far exceed what MP sold back in the day. Does it have forged pistons, & the bigger rods? If so, were the pistons designed for a g-head or swirl head? Most aftermarket pistons are designed for the swirl head. Were cylinders bored and honed with deck plate? The s-60 turbo, injectors, and two piece manifold, are always in demand and sell for decent money. Did the 2 piece manifold get ported at all? They ALL had pretty horrendous core shift as cast. Did the TB area get opened up for a bigger throttle body? Does this have NOS fuel rail? If so, that increases the intakes value. Even the NOS oil line, and TII coolant return lines and fittings have some value, as they're all NS1 now. Does it have a ported exhaust manifold? A well ported ex. manifold can flow 30-35% more than a stocker. Looks like you have a 86+ distributor installed. The 86 distributor was typically used with 86 and later swirl cylinder heads and ECU calibrations.
My suggestion is if you are going to try to sell the engine is to list in detail exactly what you have and provide additional photos and receipts if you still have them.
Good luck,
Todd
Good luck,
Todd
Yes it is a early block short block is a T2 with steel crank and Turbo 2 rods. block was o'ringed all work was done at Arrow Racing where all Team Shelby work was done. The block was done with a deck plate this engine has need been fire head was done by Tim who did all of Chrysler race stuff. The motor is a copy of the motor in Dave Zelkowski car that was in the One lap of America.
heads and mains are bolts intake was pinned and ported. bigger TBI. a nice package for someone in need of a engine trans package have pictures of all. was a 312HP
270165
1987 Shelby GLHS #0958
What was the car? If you were building an S60 set up from scratch, I would love to hear more about the project. You can PM me, as I am sure Doctordodge is tired of the derail.
Discussion Starter #25
Kinda but it's all good. I like learning about all this too. Still have the '88 Shelby Daytona that I bought the kit for years ago. I gave it to my son but he let it fall apart. It is complete with no interior. Man, that thing was fast. I'm a B body guy and don't need these parts anymore.
im trying to send you a private message and make you an offer for these parts but I cant seem to figure it out. if you could message me ill make you an offer thanks.
The new messaging system is called "Conversations". I sent you a message about how to message. It should be highlighted under the account details drop down at the top right of your screen.:)
21 - 29 of 29 Posts
