The Super 70 turbo is from my van (RIP), but I guess I'm not a turbo builder as it has shaft play from front to rear. I disassembled it to check the wheels, as you can see in the pics, and everything appears to be in good working order - except you will have to, at the very least, replace the thrust bearing. This one's kind of unique in that I also used the Grand National turbine wheel which is much nicer than the stock turbine wheel - lighter and much more efficient (see pic), but I had to have the exhaust housing machined to accept the wheel and properly relocate the turbine wheel (and center section) about 1/8" deeper into the housing - therefore this turbine housing will only work with the Grand National wheel from now on. The turbine housing is much better than it looks as there's no broken bolts and the threads are all good and it's 0.48 A/R. The compressor housing and backplate was machined straight from Turbonetics for the wheel, and I bought a red anodized wastegate actuator bracket from Cindy at FWD performance. The actual wastegate actuator does not come with it, just the bracket - sorry, I forgot to remove it before the pics. - $200 for all + shipping or if you just want the wheel, compressor housing and backplate - $125 + shipping
Thanks,
Howard
Thanks,
Howard
