I just swapped my 91 oil pump into my 88 turbo block and forgot that the only gasket avail is the cork
However I still have my 91 common block with the bigger oil pan which I can use a 1 piece gasket. Sooo
If I change out the lower cover that sits behind the timing belt sprocket will this pan fit.
A better question might be will that lower cover fit on the 88 block.
Thanks for the help
Scott
Thanks for the help
Scott
