1 - 13 of 13 Posts
I have a 1989 Daytona Shelby. Will a system check plug right into where my boost gauge, and message center is? Do I have to get pig tails, or horse around with a bunch of wires and possibly ruin my harness? Lol! I'm a little hesitant if you can't tell! Thanks for the help! Reply please! :thumb: Sorry I accedently put this in the Exterior! Ehh.. it's all the same right? Haha!
your thinkin of the navigator computer ^ , yeah that would have the conectors already in place in most cases
but ,
the systems check uses a diff plug than the message center - you could get the message center functions to work in the systems check if you splice on the plug for the S check to the wireing from the mess center
if I remember right you would also have to add a ground wire from the case - same one as on the nav computer - but that's easy
There is quite a bit of wiring involved in installing the Systems check, but it will fit in that slot no problem. I have this done to my 89 Daytona Shelby, also have the Voice Alert installed with it.
R.I.P Dennis Jarvis
how many function eva?
Dennis, you talking to me or the orginal post-er?
If me, I have a 24 function EVA w/System Check installed
For anyone looking back on this thread, check out the link below for excellent installation information...
The Chrysler Electronic Voice Alert
R.I.P Dennis Jarvis
Just locating the connectors has been a nightmare for me.
Dennis
R.I.P Dennis Jarvis
R.I.P Dennis Jarvis
Yes I actually have considered soldering wires to each pin. So I'm going to continue locating for the hardware. When I get the hardware and wiring installed, I will direct solder the wires. I just can't stand hack jobs.
When I first got my LeBaron it had 47 but splices in the engine bay.
Dennis
R.I.P Dennis Jarvis
Richard very good idea.
If you're willing to cut up the circuit board on the analog message center (or get a spare to cut up) you can make an adapter....
Dennis
I hear you loud and clear on hack jobs Dennis.
I once soldered wires direct to pin on something else, filled in the original connector cavity flush with silicone, left a few inches of wiring and then put on a generic 12 pin connector and one on the wring to the car. I have no pictures it was years ago, but it looked good and eliminated the "hack job" part of the job.
1 - 13 of 13 Posts
