1 - 5 of 5 Posts
OK, as most of you know i am rebuilding an 87 daytona. i got the sealant stuff worked out and am doing the paint. but looking at the T top trim I am a bit confused. I have always thought the T tops were painted semi gloss black. but it looks to me like a really dark gray matalic.so what was the color from the factory? most everyone i see paints them black.
the grey is oxidization
get the turtle wax scratch remover and give the trim a workin over
this will remove the grey and polish the black plastic better than you would think
trust me - did mine and the plastic shines like new if not so bad as to be pitted
the only painted piece is tha aluminum one on the edge of the glass panels- polish it with the turtle wax scratch remover too - it should match when all is done
this actually takes way less effort than you might think - you should be able to have the trim done in an hour or two
resist the urge to paint the plastic - all it needs is regular cleaning with the scratch remover
the stuff in the skiny green bottle
no , seriously ..
the finish was always high gloss black plastic
shoot me a pm if you wanna see a pic of a part done before / after - takes me 5 min - no prob
no , seriously ..
the plastic is pretty pitted. i had to use filler primer to fill in the pits. and because my tona is black i think i will just go with the semi gloss black to give it a bit of contrast!! thanks!!
Yea they were black. Its the ABS Plastic that turns that mettalic silver over the years. Sunlight fades it, and makes it brittle.
Jsut dont break them!
1 - 5 of 5 Posts
