1 - 17 of 17 Posts
NEGOTIABLE IF BUYING MULTIPLE ITEMS!!!
-T2 block: with pan, distributor shaft, tensioner, sprocket, oil sending unit, drain tube, oil pump and pickup- $90 pick up or $200 shipped
-T2 wiring harness: complete with every sub harness besides fuel rail harness, including all sensors, solenoids and relays $105 shipped
-T2 computers: LM and PM, both working $85 shipped
-T2 radiator hoses: upper and lower $30 shipped
-555 cables: from 87z, both cables $50 shipped
-1 89' turbo a413, chatters above 2,000rpms, must be rebuilt, no cables or converter $30 pick up only
-1 88' t1 2.2 bare block w/oil pan, never bored, needs cleaned and bored $30 pick up or $130 shipped
-1 complete mitsu with can, lines and 2.5 sv. seized and connectin band is missing $15
-1 mitsu compressor housing, good and somewhat clean $5 or free with the above mitsu
-2 89' swirl heads, complete with lifters, springs, followers, cam and rd. tooth sprocket with thermostat pipe *heads look good, cams have surface rust, no guarantees $30
-4 89' t1 intakes: 1 has TB, sensors, rail, injectors, fpr, and harness $30
2 have just a TB and sensors $15 and the last is bare $10 (all 4 for $50)
-1 2.5 oil pan, nice shape, 1 dent $10
-4 89 t1 valve covers,3 need cleaned & paint $10 each, 1 is graphite color$15
-3 PS. pumps, work, with pulleys, cut at the rubber lines, 1 is plastic tank 2 are metal $15 ea.
parts from caravan
-1 89 caravan ac pump and lines, works great $15
-1 89 ac bracket and tensioner $5
-2 van headlight bezels with good chrome and marker lights $10 each
-1 van headlight, driver side, almost NEW very clear $40 (cost $90 new)
-89 van hood, gold color, very clean, no rust or emblem $25
-2 85mph clusters, 1 has 130k miles and the other has 151k miles $15 each
86 glht parts
-1 hatch, repainted red and restickered 9/10, no rust at all, 3rd brake light wiring and KEY, has bubbling tint. $35 pick up only
-4 bumper support boot covers, 1 has a little red over spray on the bottom, cant see it on the car $12 shipped
3 door sill plastic, black and the 2 red side plastics that cover the bottom seat belts $10
-1 glht head light $15 shipped
-1 fog light and wiring, good housingand wires but broken lens $15 shipped
-1 cruise control servo and cable $5
AXELS:
1 89 intermediate shaft from shadow w/ bracket, havent tried to bang the busted cv out of it $70
1- 86 intermediate shafts from glht without bracket $40
1- 86 glht intermediate shaft w/ bracket and equal length axle $60
1- 86 glht equal length axle $20
1- 90 van (thicker center than 89) un equal shaftalmost new $30
1- 89 van unequal shaft, needs boot $15
1 89 van equal length needs band/clamp $20
1- 89 shadow equal length shaft good shape $20
Pm sent on the T2 block
Does the 89 Valve cover us the 3 peice gasket? (The end peices clip in then you use ultra blue sealant along the front and back?
Or does it use the blue stringy PITA gasket?
glht_omni said:
i have a known good 87 t2 lm for $65 shipped.
yes all 87+ valve covers use the newer 1 piece style gasket.
Hmm i was kinda hoping for the non 1 peice gasket lol. Did they make aluminum "Turbo" Valve covers that took the 2 end peices + ultra blue?
1 - 17 of 17 Posts
