1 - 5 of 5 Posts
Will a 1991 T3 engine harness matchup to the under dash bulkhead connector on a 3.0L V6 in a Daytona IROC ?
Thanks, John
L
Guest
What year Iroc? What are you trying to do use a Spirit R/T harness for a TIII conversion? If so I have a better idea.....
Negative; vastly different. '91 AA 50-way connector have different terminal assignments than the '91 AG/AJ body with 3.0 V6.
Probably be best to modify the existing '91 AG/AJ V6 harnesses to accomodate the TIII sensors, solenoids, accessories etc....
L
Guest
No DaPepster is right. I would modify your 92 V6 harness or get a 92 TI or TIII harness from an Iroc R/T for the swap. I cant totally envision the V6 harness in my head right now but alot of the wires in the 60 way will be the same as the turbo harnesses. Either way you will need a 92 or 93 TIII SBEC doing it that way. You could use part of your 91 TIII harness and part of the stock V6 harness and a 91 TIII SBEC but I would have to write you a book about how to make it work:eek:
1 - 5 of 5 Posts
