Hi guys, I'm a new member, and have a PT turbo convertible, and have had Lebaron's in the past incl. a 92 turbo 1 conv. I'm here because I have a problem of course. I'm trying to fix a 93 Lebaron coupe for an old guy in the neighborhood. It's an amber turn signal, no hidden headlight J body, which instantly blows fuse #10 (tail light). There is constant power to the fuse, and it’s OK until you turn on the park or headlights. Then, I hear a relay somewhere under the glove box click, and the fuse pops an instant later. I have a full set of 91 wiring diagrams, and I knew they changed things around a lot in 92, but my drawings are useless, the color codes are even different between the years! I have the front end lighting unplugged, and all the individual rear and license plate disconnects unplugged, and that makes no difference, so it’s either in the relay, or a wire somewhere in between places is cut or pinched. The wire leaving fuse # 10 is light gauge pink with red stripe, and I assume the relay under the glove box is the park light relay, or whatever it was called in 93. I see lots of the earlier wiring diagrams on the web, but none for the later cars with the relay box under the hood. Does anybody have a 93 to 95 lighting wiring diagram, or maybe just look at theirs and tell me the path from the #10 fuse to the main feed wire to front and back wiring? 92 would probably be the same too, don't really know. Thanks, Ed
