Has anyone swapped a TBI valve cover on a 2.2 that is carbureted? I the TBI does not have the PCV box like the carb cover. I personally like the look of the later VC.
well, yes ..
the later VC is cast aluminum and has a MUCH better gasket - making it less likely to leak 'down the road';
gasket is also easier & quicker to install .. and makes the VC easier to remove & re-install if necessary - gasket can be reused...
otherwise they look similar and both do their job..
