1 - 6 of 6 Posts
I have this turbocharger. It is a MITSUBISHI teoh4. As far as I know it is a stock unit. Probably needs a gone through with a new rebuild, but it (in my opinion) doesn't have mad shaft play [side to side, in/out] . I've had it sitting around deciding what to do with it.
The coolant feed/drain side (cant remember which side) has a broken off fitting and the turbine housing has one bolt that has snapped off. The Oxygen sensor is pretty much in there, but enough heat and brute force should get it out.
The coolant feed/return side are sometimes capped off by folks which really is no big deal for it to be used. The stud shouldn't be that hard to come out, I just don't have any taps right now to give it a whirl. As for the oxygen sensor, I will most likely bust out the heat and crack at the stubborn piece.
It all comes with what you see.
$80 shipped in the lower 48 states or $100 shipped the canada. OBO
PM for more info or if interested.
TIA
1 - 6 of 6 Posts
