Great job!!! :thumb: I didn't know there was such races as quick 16. Sounds interresting!
PS: awesome 60's on DR's!
Thanks Brian. Here's more info on NHRA Quick-16Brian Putman said:Great job!!! :thumb: I didn't know there was such races as quick 16. Sounds interresting!
Yes, he has an auto. And most of the time if set up right (converter, shift points and quality, etc.) will out ET a manual trans in our cars. Now, some type of sequential manual trans will out do an auto. But those are BIG BUCKS. I just recently dropped .77 in ET in the 1/8th after switching to an auto, with more to come after I fix the detonation problem in high gear I was having.fastglhntn said:great job!!!!!, hows do you get 11.50,s ,all i can get is 11.90 . i have the mph 4 11.50,s 117 to 119mph.are you using a auto? thanks , p.s . you,ll get them next time!!!.see,ya.
Here are the time slips so you can compare the 5spd to auto.fastglhntn said:great job!!!!!, hows do you get 11.50,s ,all i can get is 11.90 . i have the mph 4 11.50,s 117 to 119mph.are you using a auto? thanks , p.s . you,ll get them next time!!!.see,ya.
Thanks guys.Brian Putman said:Yes, he has an auto. And most of the time if set up right (converter, shift points and quality, etc.) will out ET a manual trans in our cars. Now, some type of sequential manual trans will out do an auto. But those are BIG BUCKS. I just recently dropped .77 in ET in the 1/8th after switching to an auto, with more to come after I fix the detonation problem in high gear I was having.
....speachless, just incredible Carl!DblTrbl said:The track was hooking so I also got my best street tire 60ft time of 1.757 on the qualifying run and I was on the brake at the end because this is a daily driver with no cage.
Thanks Russ.russ jerome said:....speachless, just incredible Carl!
Hey, I want that! :banana:Brian Putman said:I just recently dropped .77 in ET in the 1/8th after switching to an auto, ...
I doubt you would drop that much based off your posted time, but you could probably drop .3 in the 1/8th, with a good setup and an engine tune to work with an auto. With an auto I try and shift the power up in the rpm range, as a good torque converter will give you all the bottom end torque you will need.mock_glh said:Hey, I want that! :banana:
