I got to thinking...while I do a burnout, I see 14psi, but I am not flowing any outside air across my intercooler, so basically if I do a big ol' burnout wont I end up detonating, because the air charge will be so hot??
Possible, but how long a burnout are you doing. Excessive burnouts make the tires greasy if anything. You can heat soak the IC, I try to spray a mist of water/alcohol on it before a pass anyway, the evaporation will help keep it cool while not moving.
Also there isnt much load on the engine once the tires are spinning, not likely to detonate
Ah alright. Thank you for clearing that up.
