"A strapping young lad" with hair
Keep it coming!
Mop is more like it! lol One of the best decisions I made; Shave the head before the bald spot starts looking stupid! :thumb: No more crap in my hair when working under cars and super Low maintenance to boot! :dancing:
So the twin turbo was a plan made before we ever built anything significant as far as turbo 4 cyl's go. It was as simple as it gets. I figured (back then) on an unlimited budget, and according to what Top Drag cars were getting out of race fuel V-8's, 900hp was prob the most this platform would support, so 600hp seemed realistic for us
Now, the original plan was two stock style turbo's that would be readily upgradable to any turbo that could bolt in the stock location. (but two S60's was really the plan)
Those two turbo's would be driven via an equal length header, then equal length charge pipes would feed two stock I/C's and then equal length pipes back to the twin stock (46mm) TB's and a split intake feeding 2 cyl's each.
Notice how the Equal length side of the equation is slowly taking over the build.
This was a Big deal for me back then. The idea, that If everything is kept equal length, then the over-all stress on the engine as a whole will be distributed as evenly as possible, allowing the Most power to be made before failure. Only a theory of mine at the time, but again, this was where I was at thinking wise through all of this)
So once built and functioning, Everything would be bolt-on upgradable! Need more turbo, bolt it on. Need more TB, slap on a couple 52mm's ect ect, and for fueling, to stay with the "simple" approach we would run the S-60 SMEC with the +40's and 3 bar map, but add a second fuel rail to the back side of the intake with a pressure switch to turn it on anywhere along the boost curve to add fuel as we made more power.
So again, everything easily available to us and no "BIG TICKET" items to buy.
Unknowns for us at the time; How far would the stock trannies take us, and Could I drive a stick into the 9's? (so going auto was always a distant thought, but the thought was still there)
How far would the stock turbo roller cam go? Yes, we were going to run the stock roller as far as we could, then switch to full mechanical (N/A) cams offered by Ma Mopar and see how things went.
After all, we never bought into the whole "It's a turbo motor, so everything is completely different than N/A" argument. We felt that there was really No difference, other than going too big on anything, porting, pipe size TB size ect ect could be Masked by the turbochargers. So a More forgiving environment than an N/A build in our eyes. In other words; To build the ultimate turbo motor, start with an All-out N/A build and go from there.
I'll never forget all the arguments I would get into with people about the header. They all thought I should be using much smaller tubing to increase exhaust velocity to "spool" the two turbo's. My take on that; we're shooting for 600hp here, I need to design the header to allow the mtr to Breath 600hp, it really has nothing to do with anything after that! When the exhaust comes out of the mtr through the right sized cross sectional tubing, the rest will fall into place and work as it should. Seemed to make sense to me..........lol
I will admit though, that the first mock up header, was exactly that, a prototype mock-up. So I built it out of mild steel as it was never meant to serve any serious duty's. I would build a "jig" and replicate it in SS when the time was right. So the original twin turbo header was 1 5/8 header tubing with an ID of about 1.5".
