I got tired of constantly going back and forth locating p/n's for my '87 GLHS, so I made a list.
The part #'s were sourced from the 1987 Shelby Charger Unique Parts List that was published in The Shelby Times Magazine.
The Chrysler parts book was only used when a part wasn't listed in the Shelby parts listing.
I'll add to this list as I find more things.
Special thanks to GLHS0815 and NAJ for providing the correct p/n for the engine temp. sending unit.
Relays:
A/C Clutch Cutout 4339496
Located next to the ignition coil and horn.
Fan 4221615
Located on the drivers side shock tower.
Horn 4221658
Located in the fuse panel on the drivers side.
Starter 5226138
Sensors:
Charge Temp. 5226355 (Standard p/n AX7).
Rear of intake manifold - passenger side.
Coolant Temp. 5226374 (NTK EF0010)
Inlet hose neck directly below & in front of spark plug #3.
Detonation (Knock) 5213629 (Alt. p/n's: 4700044, 4671185 not verified).
Front of manifold
Engine Temp. Sending Unit w/Gauge: 4051687
Under spark plug #1 (alt. p/n's: Chrysler 4504203 & Standard TS-176).
O2 Sensor 5227368 (NTK 23005, Bosch 13190, Denso 234-3003).
Located on the swing valve (exhaust side of the turbo).
Speed Distance Sensor 4312032 (NTK VB0042)
Connects to the end of the speedo cable.
Solenoid:
Quad Vacuum 5226352
Located on the passenger side shock tower.
Relays:
Fan 4221615
Horn 4221658
Starter 5226138
Sensors:
Front of manifold
Solenoid:
Quad Vacuum 5226352
