So I set the timing belt tension to 95 then rotated the engine twice and the belt keeps reading higher then it was before tried it a couple times and it always gets tighter, why is this?
Mike
D
Guest
make sure you pull the cams towards each other to get the slack out. also make sure you loosen the rockers while setting it. the write up is in the TIII section as a sticky
