21 - 25 of 25 Posts
I've got cca 85% of oil with the small rubber hose through the filling hole, than demounted the axle and got next cca 5% but here is not enough room to put the hose too much inside, it was like a gynecologic operation :-D Than I poured 1,8 litres via filling hole and than 0,1 litre via upper small ventilating hole...
Chrysler says that to drain the oil from the Transaxle you should remove the side cover.
Here are the instructions from the Factory Service Manual.
The easiest way of course is to use a Fluid Evacuator if you have access to one.
https://www.tooltopia.com/mityvac-7400.aspx
21 - 25 of 25 Posts
