I have a 86 mini 5spd tranny (a520? pre 87 so no tag on it) and shifter. I have an a555, will the shifter work with the a555? Both cases are nearly the same with a slight difference in the starter area. The other difference is in the shift fork lever thingy that has the two ball joints for the cable ends. One lever is slightly longer with heim joint. The lever that is on the 520 looks like it will swap to the 555 and therefore use the same cables and shifter. Anyone one know for sure?
Thanx,
Deric
Thanx,
Deric
