Car is a 2.5 turbo shelby tona. doesn,t want to start when cold but if fine after it ran for a bit. While idleing you can hear it skip a bit. Idleing in gear it almost stalls the revs back up to about 1100 then idles normal the does it over and over but not consistant.
While driving its almost like its running out of fuel, very chopppy.
Now because i have many parts here,s what i,ve ruled out.
The car throws no codes.
Fuel pressure is at 48psi and doesn,t move when the car acts up
Changed fuel rail/injectors.fuel pressure reg (didn,t help)
Changed throttle body/with both sensors (didn,t help)
Changed hep (no change)
Swapped computer (no change)
Changed map/barosensor (no help)
Other than coil i can,t realy think of what else to change?
It is not a little miss. When i have the wheels blocked in gear idleing and it starts to act up the whole car rocks back and forth.
Any guestimates or ideas would be great. thanks.
