Anybody know a tight radius 90* elbow 4" at turbo and 3" after the bend, or do you know of a smaller diameter brake booster, I've tried both the automatic & manual trans boosters and both push on the red turbo inlet elbow.
Are you saying you removed the power brake booster and your braking improved having manual brakes?I ditch the booster on my cars. I dont like the time delay they inherently all have.
Braking performance actually improves!
Keep posting pics please!!
I was wondering the same thing about the pushrod.Excellent Lancer!
I was happy about this thread because it made me consider dumping the weight of the booster out of my GLHS. Randy, do you need a particular MC or do you need to make a special pushrod to run manual brakes?
I know that L bodies did have a manual MC at some point but I don't know if it would push the Shelby Charger brakes.
And the elliptical shape and bolt pattern for the MC is completely different from the square pattern at the firewall.I know that L bodies did have a manual MC at some point but I don't know if it would push the Shelby Charger brakes.
[/QUOTE]I always used a manual master from an L body with its supplied pushrod.
The firewall mounting bracket is wonderfully and mysteriously designed.
I'll write on the bracket a little later when I have some spare time.
I sent my last bracket to Shadow to copy so he could make one.
I've been meaning to contact him to see if he made spares.
Or even drawings as I have at least one more to convert.
He probably sent mine back but I can't find it anywhere.
I had a stroke shortly after and my memory is foggy.
Brake response time is noticeably reduced.
The extra space is a nice bonus!!
Pedal effort is adjustable.
QUOTE="INSATANSSEAT, post: 4528095, member: 99889"]
Excellent Lancer!
