1 - 5 of 5 Posts
hello so i was looking at my turbo and the middle of the turbo where the silver part is its like the round part of the turbo and bolts go thru it the gasket that gos all arowend that is where my oil leak is other then that the turbo is fine. also when i drive for a wile i will stop at a red light and it smokes like crazy is that cuz the turbo? its like a gray blue smoke comming out my tail pipe i no its not a head gasket cuz the motor is brand new but once i start diving again it gos away and most the time its when im in gear 1 2 3 R not N or P
R.I.P Dennis Jarvis
Turbo Charger gasket Felpro ES72643 can get at autozone.
Dennis
ok i went to autozone online and i found this gasket kit the part # is 15004will that redo all my gaskets on the turbo?
Sounds like the front seal in the turbo is leaking, those gaskets won't fix that. Gotta have the turbo pulled and at the very least replace the front seals, but makes more sense just to do a complete rebuild on it.
R.I.P Dennis Jarvis
1 - 5 of 5 Posts
