does anyone know how to block off the stock wastegate on a dodge daytona turbo I, and which lines are which as far as the oil or coolant lines?
my turbo is the one without a central intake side (it has both the in and the out side of intake around the perimeter, not the in at the middle like modern turbos)
i have 4 lines for oil and coolant, but i'm not sure which is which
i have a synapse engineering wastegate that i wish to run (40mm wastegate if you need to know) instead of the factory wastegate, so i need to know what all i need to change to run that
