Well, first off, performance will suck. The turbo motors are only about 8.4:1 compression, so you are going to lose tons of power. The spark curve won't be right because the lower compression will want a lot more advance.
Will it run? Probably, but you won't be happy with it.
Also, being a 92, I'm guessing it was originally a 2.5. Is the new motor a 2.5 as well? If not, the fuel curve will be off as well.
