the past month I bought from FWD a turbonetics t3/t4 trim 50 stage 1 and it was installed on my mexican spirit R/T 2.5 turbo, but I can't get more than 7 psi of boost even when the rpm are on 5000/5500, so I decided to go to a pressure test and it was a fuk&%$n leak on the compressor housing, so I had to remove the turbo from the engine to see what's going on and...
... the turbo didn't have an o'ring or gasket
well, after that with a new gasket and all the stuff and turbo ok installed on my car, once again I cant get more than 7 psi,
**I checked pressure test ok,
**the can actuator is very very strong to move(so is not leaking for the swingvalve, even Its was revised for proper seating of the coin)
**I checked the proper seating from the exhaust flange and the turbo ok
any suggestions please
