Ok, this is actually my first post on here, but I have to say, I've gotten more than my fair share of useful information to get my project started already!
A little backstory, I bought this car and the previous owner insured it me it only had a few issues and needed a head gasket. So I replaced the head gasket, timing drive, all the belts, pcv, ignition system, thermostat and restored the vacuum lines to the factory routing. The car is 1989 spirit 2.5 TI with the TII intercooler and BOV. After getting all this buttoned up, new oil, new coolant, I'm ready to start the motor with a brand-new battery.
Get in the car, which has been sitting for probably a year or two, and put the key in the ignition. Almost everything works, windows, locks, lights, etc. I turn the key to on, everything is good. Turn the key to start and EVERYTHING DIES. No lights at all, no more fuel pump sound, nothing.
Notes: Key barely stays in ignition cylinder (bad ignition switch?)
Has some non-factory wiring under the dash (might have shorted, but didn't notice smoke or sparks)
Passenger side ground straps are pretty rough
Most of the wiring looks pretty good, connector contacts all look decent.
I had forgotten to attach the idle and TPS connectors at the throttle body
Brake switch was disconnected, I connected it, but it was pretty corroded.
-Could I have shorted something in the ignition circuit to kill the whole car?
-Could all fusible links have gone at once?
-Could I have blown the ground straps and eliminated the ground from block to chassis?
-Could my new coil be to blame? (says use external resistor, but I assume that refers to the resistive wires used)
-Could this be ASD related? (is there a quick way to rule that out?)
I hope that's enough information, I need this thing running! Sorry for the long story.
